  • Replies 132
Hi Pete,
I have followed the instructions on your website, and now have the USB key taped to my buttocks. However, it is uncomfortable when I sit down. Can you address this in a future release?
Thanks
P.S. will try it out tonight :(
You just have to get everything i have dont ya Geoff :)
Recieved my cable and usb yesterday, very happy, will try to give it a workout tonight or over the weekend. Thanks NewKleer.
Regards
Paul
cool, thats all for the moment, might get to make some more next weekend, if my arms havent fallen off from nonstop typing of my thesis until then!
Peter
for people with usb converters who want TECU to work, ive added this to bottom of readme page:
Important: TECU is assy with any COM port other than COM1 and sometimes COM2.
To have any chance of it working with USB/Serial, you need to force COM port to COM1 or COM2 (whichever isnt in use):
1) Find "USB Serial Port (COMX)" in device manager (see above to find this)
2) Right Click, Properties -> Port settings -> Advanced -> Change port number on dropdown.
3) It will say its in use, but if u know it isnt (ie u dont have modem or bluetooth or anything there) then just confirm/continue/ok etc.
4) Open TECU, on main startup screen it where it says "Com Port:1" in bottom left corner - double click this to change to COM2 if you set converter to COM2.
Is there any chance of getting one now? I see there is a reserved list, could I be added to that (though can't see why ppl wouldnt take it, great price!)
Cheers
back at post #81 at least i stopped adding reserves cause its unlikely anymore than those there (and then maybe not all of them) will get one. but if somehow more are available or lots pull out, ive got the order that people have posted in here as reference. basically anyone thats not on the list shouldnt wait around for one if they need one, cause its unlikely you'll end up getting one.
hi pete
just tried this out it connects up ok with ecu talk but the gages don't work
when trying to change com port on the tecu it comes up with error opening com.dat file or error opening com port, i press ok then it opens up, i tried double clicking where it says come port in the lower left corner and comes up run time error 8002 invalid port number and then closes.
can you help i am also using vista 32
cheers mitch
other people have commented that ecutalk doesnt work with vista
im guessing by the sounds of things, tecu doesnt either? (you set it to COM2 i assume)
ill have a .net 2.0 version of ecutalk in a month or two which may work better with vista. when i get a new pc setup by end of month ill try dual boot etc with vista so i can try and make sure ecutalk works with it.
tried calumsult? try conzult_free and nissan datascan (can use the dash without buying it)
http://202.43.226.57/NissanDataScan1_52.zip
http://300zx-twinturbo.com/conzult/software/free_conzult.exe
haven't tried either so will do. and no, how do you set to com 2 not really that great with computers
try srtalk
http://www.zcontrol.net/Default.asp
also datalog dyno but needs a few things installed:
http://www.neoed.servaus.net/DatalogDyno.htm
or obdscantech (free version has popups every 10s)
http://obdscantech.cjb.net/
cables working good and looks the piece. managed to get nissan data scan and works fine with vista tried it out today but will give it a better test tomorrow when i have more time
cheers Mitch
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
    • Good on you for mentioning, that helps as far as other things you might need to check
