Hi all,
After selling my R33 gtst I have a few bits lying around the garage that I need to get rid of to make room for new projects.
Except for the car ramps, centre console and the rear wing, I am happy to send items at the buyers expense (I'm located in Melb).
As these prices are already bargain basement, I am pretty firm on them but feel free to make an offer via PM as long as a no won't offend! :santa: Also if you are interested in an item and would like more pictures, feel free to ask but please don't waste my time.
1. Stanfred Car Ramps - brand new, never used $60 -SOLD
Steel contruction, 750kg load rating per ramp, approx 210-220mm high.
2. Bendix Ultimate rear brake pads to suit R33 gtst - brand new $80 $70 -SOLD
3. Defi 60mm Gauge mounting pods x3 - brand new $10 each -SOLD
To suit BF series gauges...will probably fit others but not sure.
4. Spare Defi gauge parts - brand new $10 for the lot -SOLD
1x meter wire
4x solderless connectors etc to suit control unit II
5. Std R33 gtst BOV - $40 -SOLD
Perfect working order and only replaced with an upgarde aftermarket item.
6. Std series 2 R33 gtst rear wing - $70 -SOLD
Black in colour (KH3), no nicks but has a few scratches and will require a repaint. Note that when removed ALL L.E.D.S. in the brake light were in perfect working order. Also has light connector and both rubber 'gaskets' (see picture).
7. Std R33 gtst gauge cluster - $80 -SOLD
Removed at 86,481km and replaced with 320kmh item. Was in good working order.
8. Std R33 gtst centre console - $40
No scratches or nicks and in great condition. The lids latch was broken however it has been fixed and works well.
9. Autotecnica 340mm steering wheel - $140
Like new. Red/black leather. No sctratches or tears in the leather. 35mm thick wheel rim.
https://www.sau.com.au/forums/topic/165678-garage-clean-out/
  • 3 weeks later...
^ +1 need a few more shots of the mounts and dimensions. PM meyour details. i'll take 1 now and test it out then take the others if all is good. yay 1 sold 2 me lol how deep is the actual mount anyways? jus wondering if can fit other gaues into there...where you located? i think might be better if i take all 3 now considering i gota pay postage if out off sydney...
Edited by bloodsword27
Hey guys,
The only shots I have of the cups with me are these:
I don't have dimensions with me but they were supplied with 60mm Defi BF gauges. You stick the metal mount plate (red circle) where you want on your dash (is thin metal so will bend to suit shapes) and you use the bolt (blue arrow) to attach the cup on the angle you want).
As the ad says I'm located in Melb.
Bloodsword....err I'm getting a fair bit of interest in people wanting all three....if you want to take all three postage to Sydney shouldn't be any more than about 5-10bucks
Ah geez no interest in these items for weeks and all of a sudden theres a rush on :cheers:
Really sorry bloodsword, but when you didn't reply I agreed to sell them to someone else. Once again I apologise but I'll know in a day or so if that sale falls through and they are yours if thats the case
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
