hey guys i got the car tuned today but on the dyno graph the psi is droping from 14psi to 11psi is this normal i got a gizzmo boost controller and the setting is on 56 duty cycle and the gain is 0 would it be my wastegate and also its a highflow gcg turbo
Edited by Jsikalias
https://www.sau.com.au/forums/topic/165742-boost-problem/
What boost controler you using because it sounds like its spiking then going back to stock boost
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069294
From what I've seen of those controllers they are quite shit!! If an EBC has no PI or PID based boost control then you may as well just use a bleed valve. From memory you set the boost from a base duty cycle not an actual desired boost pressure so there is probably no brains behind it anyway.
You could try setting the gain to a higher value but it probably wont work anyway. If it is possible which I dont think it is you could check the duty cycle on the valve to see if its attempting to control the boost. As has allready been said it may be a mechanical restriction.
Edited by rob82
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3069512
I had a similar problem and discovered the wastegate arm was hitting the bracket that holds the heat cover because the new dump had a thinner flange.This prevented the wastegate from opening fully and capping boost to 15psi.Anthing over and boost would spike all over the place.However,the duty cycle could be lowered then turn up gain til it spikes then back off a little.
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3070215
its the gizzmo boost controller,
they are known to spike. i have 2 mates that have had em in their cars and the cun*ts spiked like crazy.
my suggection, get rid of the gizzmo and buy and apexi or similar
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072367
yeh the tuner said it could be my wastegate BUT i found the problem, because i have an aftermarket intercooler the new piping didnt give me a nipple for the powersteering vacum so i T pieced it off the boost controller vacum so iv removed the T piece and now it doesnt drop boost it holds 14-15 nice feels faster as well
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072480
go to like super cheap or repco and buy an air compressor fitting. they thread and can easily be drilled and screwed into the cooler pipe. plus add some sealant around it and ur done.
should look like this hen done
https://www.sau.com.au/forums/topic/165742-boost-problem/#findComment-3072561
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
