For it to be there so long, without need for it to be covered, id assume the owner doesnt mind bout ppl knowing, or the real secretes unseen :ermm:
For what ever reason, I didn't want to start a thread bout trying to put information together and start a rumor mill ( thanks for not naming workshop Leech ) :P
I was hoping to chat to the owner about his setup, as mines quiet similar :D
I'm aware mods, this inst really the intended use of forum :huh:
Cheers
