Morning All
I'm thinking the pump may be gone/going in my r32. The power steering works fine for the first few minutes of driving then it all of a sudden switches off and its like steering my old datsun. Any ideas??? should i just change the pump?
https://www.sau.com.au/forums/topic/166316-power-steering/
is your speedo working?
if so check the solenoid wiring to the power steering rack to ensure the rack is still recieving the power signal from the ecu that controls its assistance
Yeah speedo is still working. i'll check it out over the wknd. thanks. Has this happened to anyone else? i havent really heard of it being a common problem.
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3080494
hey thats liek me! lol i was asking this question a while back but no one answered :)
ill keep an eye on this thread.
its liek all of a sudden turns off, but mine is at random times... so i would usually stop and then flick the switch to rwd, then back to 4wd. usually fixes it
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3080581
check fluids in both power steering and hicas. watch speedo CAREFULLY and see if it is bouncing. even just a little bit. sign of worn speedo cable. this does affect steering. check hicas computer bolted to the bottom of the parcel shelf in the boot. theres a light on it that will blink if theres any errors. error codes are in the service manual
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3082011
There's a light on the HICAS module? where abouts.. There's one on the attessa module, but even the workshop manual only shows to check the dash light once in diagnostic mode for hicas, not any mention of an led indicator..
James.
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3082072
I checked the fluids a few months ago when it first started happening. I actually had the speedo re-calibrated about 8-10months ago when it was reading ridiculously random speeds. i have noticed that it is bouncing slightly though. The Hicas light usually comes on after the power steering has stopped. they run off the same pump, but they stop at different times??? or would there just be a delay for the hicas stuffing up?
https://www.sau.com.au/forums/topic/166316-power-steering/#findComment-3083241
  • 4 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
