Hey,
cars is for sale.......
92mdl R32 Skyline GTS-T, RB20DET, Stock Turbo, Custom FMIC & 3" Piping, Custom Front Bar, Tein HA Suspension, 17" Enkei RP01's, 3 1/4" Zorst, Locker Diff, New Gearbox, Race Clutch, Boost Gauge, Chipped ECU, Oil Catch Can, F/R Strut Braces, JVC MP3 Headunit, car is in excellent condition, regretful sale as i have a baby due any day now and that is more important to me at the moment.............
Steve
Thanks to all that have enquired about my car but i have now sold it...........
https://www.sau.com.au/forums/topic/16648-fs-phat-32/
  • 3 years later...
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
