Time to sell a true classic
1994 R32 GTR (white)
Full years rego
Will supply roadworthy
Car in Melbourne
Price $ 36,000
I have searched for a around a year looking for a very clean last of the 32 gtrs in stock condition and finally found this beauty, i am the first owner of this car and as you see in the photos it is no longer very stock.
I have driven many R32 gtrs and none of the ones i drove compare to this fine example. There are plenty cheap 89-90 models floating around but most are total rubbish. Why buy a 89 R32 when for a little more you can buy one that is 5 years younger and with all the right goodies on it. Go and drive as many R32 gtrs as you can and then drive mine and make up your own mind.
Anyway the car was stock when i bought it around a year ago and since then it has only travelled around 2000 km's.
All current modifications installed 2 March, 2007 where done by RacingLine Motorsport (Cheltenham)
All parts listed below are all brand new and on the car less than two months and 400kms old.
Apexi Power FC
Nismo Air flow meters
Nismo 600cc injectors
Nismo fuel pump
Nismo fuel pressure regulator
Hks split dump pipes
Tomei Poncams 260 IN/EX 9.15mm lift
Garrett GT2860R-(5) turbos
Genuine Nissan Water Pump
Genuine Nissan Timing Belt
New Tensioner and idler bearings
Adjustable steel cam gears
Extreme HD clutch kit
K&N filter panel
Metal cat 3.5"
Endless super Street Y Sport front pads
Blitz dual SBC
NGK BCP7ES plugs
All fluids - engine, coolant, brake fluid, diffs, gearbox, attessa etc have been replaced with redline/castrol oils.
Airconditioning - compessor has been reconditioned and regased.
Car has spent may hours on dyno to get the tuning right, it currently has 330awkw.
Other second hand parts include:
Tanabe Pro coilover suspension
Full stainless front pipes, cat and rear exhaust
18" X 9 BBS wheels (gold)
Also have most original parts from car.
This car has it all and all engine parts are all brand new and i have all the original boxes for them.
I have all the paper work for the modifications and you can talk to Racingline motorsport to confirm anything done on the car.
If your looking for a genuine clean R32 GTR with all the right stuff, look no further this car will not dissapoint.
Please no time wasters only genuine enquires thanks
Post or call me on 0417 585 573
Edited by arrow
https://www.sau.com.au/forums/topic/166507-1994-r32-gtr-330awkw-immaculate/
RNS-11Z
First you cannot say look at my price without seeing in the flesh what is on offer.
Secondly this is a 1994 model one of the few around and not an 1989-90 model. The car is in great condition and all the modifications listed are brand new and set me back over $15,000.
I know you can get ones for around 20-25k but most are shitters and can not compare with what i have for sale.
Anyway not trying to be nasty, any genuine buyers who see this car will not be disappointed.
And price can be flexible.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
