where do i put it on and does it matter if i put it reverse ,like the wrong way round? do they only flow 1 way or doesnt it matter. how many turns wud i need to do to make the boost go up coz i dont wanna turn it half a turn or watever and it goes up to 20 psi or something. its sum cheap crap 1 it looks like but shud do hopefully
https://www.sau.com.au/forums/topic/166526-hooking-up-boost-controller/
Find out what model it is then look it up on the internet.
I have a GFB one and it was a piece of piss to install, as it had arrows pointing torwards the actuator. I would reccomend not running any more then 10psi as causes problems with boost spike and even maybe kill your turbo.
turn it 1/4 turn at a time, making sure that you take your car for a drive inbetween turns as that will allow you to see actually how much boost is running.
I am unsure if it matters what way the flow goes through the boost controllor, but mine does have an arrow in it that in the instructions it said point towards the actuator, so I am guessing that it would be best to check this with the model of controllor you have.
Cheers
Chris
