Would any 1 happen to know the aprox price of the trust frontbar? Or if some1 has it, how much it cost them. not inc paint and fitting.
Thanks!
looks like this;
I am also looking at getting that front bar. Ask PSI parts on here, i have heard nothing but good things about them and good things about the fitment of there items. Have spoken to them a few times and they are quick to reply and very helpful
Edited by Adz2332
https://www.sau.com.au/forums/topic/166874-trust-frontbar/#findComment-3087918
cheers :P
https://www.sau.com.au/forums/topic/166874-trust-frontbar/#findComment-3093070
