Hi
As the heading states I found this dyno graph for an R34 GT-t which says that had a gain of 56KW from installing a POD, Low mount headers and a FMIC.
Does this seem too good to be true?
Do you get any gain out of changing headers?
http://www.driftsideracing.com/templates/d..._gts/image2.jpg
Any thoughts or comments?
https://www.sau.com.au/forums/topic/167747-r34-with-pod-headers-fmic-and-176kw/
  • 5 months later...
Thanks i think that pretty much answers my question.
Hi there, i own the car.And its siting outside still standard. The Dyno report is correct. There are doubts about the transtune Dyno in Whangarei NZ.End of the day there only used for tuning.But The increase is clear. pod,front mount,front pipe,gone with the cat,and headers. And its tiptronic :laughing-smiley-014:
So a hub dyno? Interesting to see you've listed a couple of more mods than whats writting as "mods" on the sheet.
Either way, exhaust manifold is a waste of money.
Could have spent the money towards a good ECU and made much more power
the low mount heaaders are free because i sell them :laugh: and they did improve the rv range over 140k-cut out. The front pipe..i dont know but it looks good!! cesracing front pipe. And the dyno was one of the ones that has the rollers on the ground.
As for ems..i couldnt afford it and it was a new car.and its tiptroic.So at the time i couldnt use an aftermarket ecu. I have a 34 manual box now and plan to use a link rather than powerfc. Along with a dsr top mount and dsr430 turbo.Its enough and should do reasonably well keeping in mind its just a show what dsr products look like car
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
