  • Replies 120
hahah salad is just a moron thats why he got jess :laugh: hahah nah pub crawls are crap because ur on a bus plus ur not in a skyline and i dont drink so theres no point in going to pubs haha so whos plan my friday night for me any one want to go on a random drive any way :D
Make up your own map as you go hey? Sounds like a good plan.
Cant do it this week though. Car still not going yet and its racing sunday so will be a bad time. In next few weeks id be happy to do something like that...or see if dan can give you an old map.
yo we can tie ur car to my car then we have a two person cruise haha i dont even think i have petty hahaha :D haha nah i just wanted to meet jbaby haha :wave:
Well if you want to meet her, why not try your best pick up line and see if that helps? LOL
Chicks dig pick up line :laugh:
LOL i had to work for a bit!!!
im back now.
u can try a pick up line.
u might of even seen me at the cruise last friday only one with pink neoons on!!!
I like your name. Shall we discuss it further over some drinks? :domokun:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
