  • Replies 120
i think it funny that ossie is going to be home all tonight and tomorrow waiting hahaha
only playn ossie :domokun:
haha so whose coming on a cruise with me or in the case of ladies viewing this post whos coming out to dinner with me and a evening u wont forget hehe (this includes a lovely dinner at mac donalds followed by a sunset cruise down to freo ) :no: haha
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
