haha yeah i dont know eh we were talking about hamburgers then he said keep it semi clean i know burgers can be messy but i eat them pretty cleanely i thought must be wrong :domokun: but i hear romours about the hygeine in maccas as well but more about ronald hes a dirty boy
  • Replies 120
no just anti clown today but they so annoying they put girls makeup on then scare people and steal girls so they have to get kicked in the mc nuggets and i think it is the clowns that have issues not me hahahaha :domokun: bash the clowns
HI u have just read 6 pages trying to find a cruise but to no avail sorry to disapoint u but there is a really good convo going on it changes direction ever couple minutes :domokun: hehe if u are a girl reading this then u are truely cool and would uo like to acompany me to hungry jacks then on a cruise to freo as i have clown issues at maccas :no:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
