Just thought i'd post up a picture of my 1984 300c. I'm pretty happy with it so far (had it for 8 months) - and i've only seen 2 -3 others around Melbourne during that time. It runs the vg30e motor with a 4 speed auto. Gets up to 100 around the 10 sec mark, and handles really well too.
Might do some sort of engine conversion later on, or just lower it slightly and give it a fresh paint job.
https://www.sau.com.au/forums/topic/168552-my-300c/
Hi there,
Nice looking car. Seems to have been looked after very well. I'm sure I'll see you around the traps. Be sure to wave and say hi!
yeah i bought it of a dealer my friend knew who said it was traded in by some old bloke, so i got a pretty good price as they probably took it off his hands for next to nothing :rofl:
https://www.sau.com.au/forums/topic/168552-my-300c/#findComment-3115634
  • 3 weeks later...
  • 2 months later...
  • 5 weeks later...
Well the car isnt at my house at the moment, partly because there is no space and partly to prevent me driving it :wave: but maybe this summer come around and we'll compare
I'm actually trying to source a motor for it at the moment, as the timing belt pulley bearing broke and i got a new pulley and belt put on it but its had a miss in it since- im thinking maybe a bent valve somewhere..
i got a quote at 660 but that particular wreckers didnt have any in stock. i might ring the one in centre road, see how many kms are on the one u mentioned..
https://www.sau.com.au/forums/topic/168552-my-300c/#findComment-3363510
  • 1 month later...
I cant fit spacers, otherwise it starts rubbing the inner guard in the rear. It's pretty tight in there due to it's height. The fronts I'm running 5mm spacers to clear the struts. If I go any bigger, I wont be able to steer the bloody thing!
https://www.sau.com.au/forums/topic/168552-my-300c/#findComment-3500936
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
