Hey all,
Does anyone have any pics of the different Bonnet options available for the R34 skyline. Im getting the R34 front converstion kit for my 33 and they have told me i can have any bonnet i lik just tell them which one, unfortunatly i cant find many pics of them. Are there many options available?
Please post some pics
Thanks
Adam
https://www.sau.com.au/forums/topic/168596-r34-bonnet-options/
Hey all,
Thanks
Adam
This vid might interest you. Looks pretty good IMO.
http://www.youtube.com/watch?v=G577HTxYnfg
There are heaps available, just depending on how much you want to pay. C west, Z tune style, Top Secret, HKS, East Bear, Elektra, etc. You could get someone to make you a copy of those if your not willing to fork out so much coin.
Edited by Yawn
Hey all,
Thanks
Adam
try carmate website
www.carmate.com you can see many of bonnet from them
Cheers for the vid, yep i love it lol. mine will look abit different i guess cos mines a GTST not a GTR so the back wont be flared.. but yer cheers for that
Those bonnets go well with the GTR front bar, i'm not too sure how it'd look against a GTT or even kitted front bar though.
yer i kno what you mean its hard choosing a bonnet when u cant see it on a car with the same kit on it!
Thats the kit its going with
Mr dmd is living proof a kitted car will look good with that good .. the 3rd pic u got with the black car is pretty much it ..
Ive lost the pik but its in the forsale section ..
excellent ill try the search button and see what i come up wid id love to see the car...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
