Hey guys. Just got back from Melbourne.
Here is the roundup. Car is in Ok condition. It has a smashed front windscreen, the drivers lock has been ripped out and my left rear white wheel is missing. It looks like they took it for burnouts and when the tire blew, just chucked the rim somewhere. Also the fuel cap is damaged and they had stuffed newspaper down the tank. I guess they were going to torch it later in the night if it wasn't picked up.
They also smashed up the dash and the engine has an oil leak from the exhaust side. I hope it hasn't blown a head gasket or seal. Not sure what to do with the car. Depends on how much the windscreen is.
a20089 - I own you a case of beer or something. I will sent you a PM.
Thanks for looking guys. The police weren't much help and even after I rang them and told them were it was and could I take it, they told me I had to wait. They then organised their own tow which cost me $265 to get from the corner of Fyshwick to Fyshwick and didn't inform me until I rang them back to find out what was going on.
Cheers,
Brett
Sound like the bastards that took my last car.
Glad I could assist, you can pay for my pizza next pizza night :-) Hint Hint Veilside :D
One good thing this comunity has done for for a fellow liner owner, let it not be the last.
Cheers,
Cheers,
Paintball and pizza for the next ACT SAU get together :D?
Good to hear you got the car back, now comes the fun part of finding what those bastards have left for you and what they have taken
Hey dude,
I got a few parts, PM me what you want.
Even got a front windscreen if you pull it out yourself.
Otherwise i might buy you car.
Hello
I had another look and it is not as bad as it looks. The biggest pain is losing one of the GTS2 mags. I have another set full set of locks already (just need to TIG up the boot hole) and I got quoted $200 for a new windscreen fitted. Just need the instrument cluster and handbrake cover. Do you have extras of these that you want to sell? Also, the steering rack is leaking oil, Don't know if you got a spare rack as well?
Goes to show how strong the RB30 motor is. It must have been revved hard to pop the tyres as they still had a bit of tread on them.
All my steering racks leak... I haven't seen one that hasn't(except new/rebuilt ones).
I don't have any s3 silo instrument clusters, whats wrong with it by the way? I should have hand brake covers... what ever they are...
Instrument cluster is smashed and they also ripped out the needles off for some reason. yeah, there is not such thing as hand brake cover. I mean't the gear stick surround cover. I might have access to one of these as well. i will let you know via PM if I need you to look. Thanks for the help.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
