hey guys im wrecking my donor car.
its an R34 GT-T.
Has everything except engine , front/rear brakes, 5 speed gone and tail shaft.
Front has damage so no panels on front or radiator support. has one LHS head light though lol.
the GTT wheels arnt available either im sorry.
the rest of the car is in tact including interior except steering wheel (airbag gone off).
ok ive started the price list .
this will grow by saturday.
im not located with the car so getting to it between work hours is hard but this weekend i will know more.
mirrors- $120 each
Doors - $350 each
Boot -$250
Door Glass (tinted) - $200 each
Door trims- $150 each
Wipers - $40 pair
Rear Screen- $300 (tinted)
Dash Cluster (60,XXXk's) - $300
Dash Pad -$200
head unit bracket- $40
Glove box- $100
hand brake (inc cable) $160
Front seats - $600
rear seat - $250
parcel shelf - $50
interior carpet - $120
tail lights - $250 each or $400 a pair.
Rear tannabe coilover (non adj 8 kg springs) -$350
Front KYB SS Stuts - $200
Rear Hicas Steer rack - $250
Rear bumper - $150
tow hooks$15 each
ABS unit - $300
ABS senders - $80 per corner
Fuel tank - $200
Quater glass - $150 each
Climate control unit $150 - white shit removed ...now clear lol.
Air con pump $120
Brake master cylinder - $250
Manual Pedal box- $250
Roof Lining - $120
Interior light - $30
Dash Gauges (set of 3 in holder) - $180
R34 Factory Turbo (30,XXX k's no shaft play) - $550
Swaybars - $60 each end.
LHS headlight Xenon light - $250 - slight damage ...see pic. nothe to effect it working is broken. still cheap price at that price.
Factory intercooler - $80
Complianced Seatbelts - Rear only $140 for both.
Steering rack - $200
Steering surround - $50
Reverse lights - $120
wiper motor - $50
Rear Bumper Rio - $110
Interior kick and ecu panel $70 for both
Basicly the centre console down to the shifter surround is sold so that is not listed.
i have other bits like rear trims etc. just ask and i will get pics and prices for them.
also the rear quarter panels on the car are very straight and am will ling to to chop them off if there wanted.
Availible are all the door rubber seals aswell as boot.
this list will be made larger on saturday with hopefully pics for most parts.
cheers
TasR32
Edited by TasR32
https://www.sau.com.au/forums/topic/168700-wrecking-r34-gt-t-pics-up/
  • Replies 102
Location?
I'm after the 2 interior pieces. The centre console assembly and the surround that covers the gearbox tunnel, it the piece that 'wraps' around the din/facia/gearshit area and looks like it blends into the dash.
Pm's will be replied to in the morning guys.
Car is located in hobart tassie.
yes its a 2 door coupe. Black in colour.
snipper - i have the headlight on the LHS ....send PM to u in the morning.
WRX Killa - yes i have the dash it has 62,XXX k's on it.
sorry guys im at work and limited time on the pc, but PM's will be replied early in the morning.
cheers!
cheers!
Pm sent yest regarding kick panels, still awaiting reply. Cheers.
