hello, I'm planning on coming up to QLD for the AMRS round next month. I would like to stay at the gold coast ( as i want to have a look around as i want to move away from Adelaide) and are looking at a few areas (melbourne & gold coast) it will depend on organizing some work
are there any buses that go from the gold coast to somewhere near the QLD raceway circuit?
and what would be a good area for some cheapish motels ect? i have been told the Ipswich camping area but would prefer the gold coast.
sorry if these questions seem a bit stupid but i haven't been up there for over 15 years.
https://www.sau.com.au/forums/topic/169115-questions-about-gold-coast-area/
Well hmm...i dont know if there is a direct route to QR, but there is a train that goes to ipswitch and futher i think, havent done it personally.
As for cheap motels...the futher you get from the coast the cheaper it gets. So myabe nerang..which is 5 mins inland, is prob a bit cheaper. and there is a train station in nerang. might be cheaper hiring a car for the day and driving buddy, and more convenient.
Yeah QR is a good 80min drive from the GC so getting any sort of public transport is going to take at least 3 hours if not longer! Maybe you could organise to meet up with a friendly SAU member and perhaps offer a carton of beer or pay for there petrol or what not if they take you up. Something to think about >_<
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
