Hi all.
I have some second hand tyres.
They are Dunlop SP3000's. They are the same as what comes out on Falcon XR8's.
One is good condition (90% tread) except a jab near the side that has hit the belt but has not gone through.
The other is about 60% and is pretty scuffed. I got them for drifting and won't be using them anytime soon.
I would not recommend them for street. Good to burn up though. Pics show the cut and condition
Pick up in Doncaster East Melbourne.
PRICE: PRICE DROP FREE
https://www.sau.com.au/forums/topic/169571-2-x-17in-tyres/
i can vouch for this bloke.
does a really good deal. i bought a similar set, but my car is way too low so they couldnt be fitted properly without running into problems.
good trader :domokun:
good luck with the sale bro.
https://www.sau.com.au/forums/topic/169571-2-x-17in-tyres/#findComment-3136881
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
lol thats gotta piss you off man, you cant even give them away hehe. id take em but i get tyres free anyway alot closer to home.
I'll use them eventually. They'll be very hard by then though.
ill have them how much to post to bris
Won't be worth your while mate.
https://www.sau.com.au/forums/topic/169571-2-x-17in-tyres/#findComment-3396060
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
