Anyone bought from DMD?
DMD is quite expensive but im going to try and fit myself, so are they worth spending that bit more???
they sound confident in there product
I have no idea what there quality is lik and fitment etc?
I just dont wanna be screwed again..
Anyone kno? Opinions?
I have also got some quotes from motorkitz and VIVA
Anyone kno what there lik?
Anyone else you guys can recommend or any opinions plz say
Im after the BN side skirts and rear bar. Trust Front bar, Garador mirrors, Vented wider fenders, bonnet for a GTST series2 R33
Edited by Adz2332
https://www.sau.com.au/forums/topic/169842-dmd/
From what I can gather they have new manufacturers for some of their kits & quality has improved. Was over for the Syd Autosalon recently & a business trader there (Smooth) sources some of their kits from VG & they seemed pretty happy with them.
https://www.sau.com.au/forums/topic/169842-dmd/#findComment-3138821
That R34 was HAWT!!
The kit was really good too, so must of lifted there game :domokun:
https://www.sau.com.au/forums/topic/169842-dmd/#findComment-3138882
when i got my kit from viva, one of my side skirts were not fitting properly.. i just did some cutting and sanding and bending... it fit nice after all that and painting etc., :)
it was some work to prep it and get it to fit nicely.. but it was very nice in the end.
i guess you will get better quality from the plastic kits.. but they cost shit loads more than the fibreglass stuff which usually does warp.
https://www.sau.com.au/forums/topic/169842-dmd/#findComment-3139441
Just got Bn Side skirts and rear bar the other day from DMD rocked up cracked (not dmd's fault the couriers it was packaged very vell) But put the side skirts on my car they seem to fit but there to tight and crack around the corners so gona have to strengthen it up with more fibre glass i guess rear bar looks like its gona fit alrite. The only other thing im not happy with is on the side skirts as part of the skirt it says Monkey on there in the bottom back corner. This is because DMD distribute for Monkeyware house i could prolly sand it off but this should have been shown in photos or atleast told me about it before i bought it. I have heard nothing but bad about viva garage (very shit fitting kits) and when i rang them up to ask about the kit the guy was an absolute cock head so i went else where. Good luck either way you go let us know how ya go
https://www.sau.com.au/forums/topic/169842-dmd/#findComment-3141120
  • 3 months later...
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
