I've been reading as much as i can on the forums about suspension, SK's kit and Tein HA's.
I've noticed a lot of complaints about the Tein HA's - in particular the harshness of ride. I don't really understand how harsh the ride is as i'm running stock suspension now, but would it be like go-kart stiff? or would it be able to be compared to anything else?
Also, would it be any good for putting down 200rwkw? I've read a couple of stories with ppl having trouble putting power down with these coilovers although some seem to love them.
I've read about SK's setup too, and it seems like a pretty good setup (user reviews) although i may be able to get the HA's for half the price.
My question would be, should i spend the extra money and get SK's R32 gts-t setup? or go for the HA's?
Thanks in advance.
https://www.sau.com.au/forums/topic/170171-tein-has/
hey mate i've got Tein HR's and HA's.....in both my skylines well the HA has a 16 stage soft to stiff levels soo liek if u think its hell stiff turn the knob and make it soft but my tein HR their only height adjustables so they are real stiff so every little pebbles feel liek a pot hole but the HA's are ok well i danno about putting power down but i know that my Teins are awsome in the Handling wise i mean taking corners there is like prolly 0 body roll but on aussie roads it can be a bit like harsh the ride but normal roads that don't have pot holes etc will be good :stupid: hehe it is a little bumpy but waht coil overs arnt?
Cheers
Chi
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3143798
I had HA's, and yes they were Go-Kart harsh!
One had the little knob thing broken off, so i couldnt adjust the damping ratio.
They were also super low, ive got a feeling they were for a GTR (is that right?!?), because when i tried to wind down the spring to raise the car, the car didnt go any higher. It was super low = no travel = very very bumpy. I had the steering wheel to hold onto, but my passengers didnt enjoy it. Hills drives were dangerous, car would bounce around corners....
But maybe my HA's were setup wrong.
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3143889
Cheers
Chi
The harshness is mainly because of the high spring rates found in the HA. If you don't want a harsh ride, I recommend the Tein Superstreets if you are after coilovers. They are more street friendly as spring rates are closer to factory. I've proven to a lot of ppl with the mentality "all coilovers are harsh" that the Tein SS are surprisingly comfortable!
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3143950
coilovers traditionally have very stiff rides - great for responsiveness but not so good for australian roads. have seen a WRX with coilovers hit corrugations on a tarred road (the surface was just uneven.. kinda shit) and since it was around a corner the car just skipped straight over them like a rock on a pond and ploughed into a ditch.
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3145163
ive got em too and in my opinion if you can get em new for half price then get em. mine were used and knocks a bit b/c the pillow balls are worn. also my front 2 damper knobs are missing so i cant adjust them but they seem fine. yep they are damn stiff, i got sore neck the first week after 10mins driving. once you get used to them theyre great but big bumps and holes are unforgiving. makes you read the road conditions alot more. i love em but i havent been in a car with SK's setup to compare which is something thats holding me back from getting them.
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3145222
I wonder if this is a common problem, with the adjustment knobs breaking off - one of mine was broken too. Might be something to be careful with - if you own HA's, be careful not to turn the knob with too much force.
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3146882
I've got HA's on my 33 GTR and yes they are too hard because of the spring rates, but cornering and precision in handling are awesome. Once the tyres are up to temp I can easily get more G's in cornering than I can in acceleration, and thats a huge buzz. I love it!
Still, i'm changing to bilstein shocks and softer springs soon as the car is my daily driver as well and the roads in cairns are way too bumpy.
I've got easily 110mm of ride height and there is room to adjust higher if I want too.
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3148646
I've got the HAs and don't find them too hard for normal street use. Mine have the progressive spring feature tho (i.e. small spring for riding everyday bumps, big fu(k off spring for cornering etc).
I have the rears set 4 clicks from squishy, and the fronts 4 clicks from house stumps. They make cornering a dream :P
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3149776
The helper springs cant do anything for softening a ride, they bind (crush and become solid) with the weight of the car on them so the spring rate is only given by the main spring. They are only there to keep the main spring trapped at full droop.
The Tein HAs and HRs are pretty old now aren't they? I'd be wary of buying 2nd hand ones. Either way, I would just get the Whiteline/Bilstein groupbuy, for the amount of handling AND comfort you get, it's pretty hard to beat.
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3161424
I put a set of HA's in my mates mitsubishi vr4 and he loves them, reckons they were the best 700 bucks he ever spent.
But as stated sometime coi over can be a little harsh on the road, i had g4's in my r31 and loved them but reall stiff springs so occasionally i'd second guess driving it. Now i got JIC's in me cefiro and there not to bad just get to know your route to work and home a little better
https://www.sau.com.au/forums/topic/170171-tein-has/#findComment-3162871
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
