I SERIOUSLY doubt you'll find a ball-bearing turbo for under $1500. AFAIK the Highflowed SLIDE turbos are plain-bearing. In fact, I don't know that I've seen ANY ball bearing turbo's around, highflowed, new. or otherwise for under $1500. There's T3/4 hybrids kickin about new for $500 or less, but they're oil-cooled only cores. not too sure on quality or performance either.
hmmmm.. . . . . . .
How does the highflow compare to the std turbo? How noticable is it and how much diff in pwer?
Well mine isn't a slide (I'm sworn to secrecy) but I get the impression it's a similar result in power, lag, efficiency etc. The spool-up below 2,500rpm is possible, but not in the same game as the stockie. Above 3,500rpm tho, it kicks like a frikken Mule ! ! It's definitely not as "ready to go" about town when You're cruisin & give it a prod, but when you've got a few revs onboard to begin with, it's GOLD !
I don't even notice the lag 99% of the time now, just used to it I guess, & automatically adjust/pre-empt.
So its much better than standard (disregarding lag etc)? Both cars I have owned hve been turbo and Ive never upped the boost/changed a turbo before so have never had an idea of how big the increase is.
Lag is not that bad with the standard slide hi-flows, for the small amounts of loss in response there is big time gains in both mid-range and top-end power. Even if you feel it is a bit laggy there are cheap ways of improving response without breaking the bank ie. Retarding ex cam gear, advancing base ignition timing with CAS adjustment, high-flow cats, high flowing mufflers etc.
The power difference is very noticeable, boost hits hard and keeps on pushing rather than plateauing like the standard turbo's do.
Edited by BAMR33
Oh I wouldn't bother with a dead-stock Skyline, I drove a few when I bought mine, and it just ain't no fun !
I'm at about 200rwkw, and I'd say that's just nice for a road car (I've got a fat torque curve tho, 16psi boost midrange, 'til the injectors hit 100% at 5,500rpm) but just barely a starting point for trackwork, IMHO. About 18psi and 250rwkw feels REAL fiesty on the road, I've ridden in one a couple of times, and it'll light up both rears in 2nd, straight-line style. =D
The stockie's restrictive exhaust housing/exducer limits flow to 180rwkw, 190 if you're lucky (or your dyno reads optimistically)
Stock turbo comes on smooth & quick, but ultimately won't set your pants on fire. The real-deal "turbo rush" comes from the laggier, harder-hitting delivery of bigger-flowing turbos.
It's fun :/
1. No frount mount.2.Standard clutch ( when you say my clutch should be replced is this because its going to slip from more power? Or your all just assuming im going to be drifting and doing burnouts?)3.Standard fuel system.4. Piggy back ecu ( IS that what the SAFC does?)
I have a turbo back exhaust (with standard dump pipe),
That's not a 'turbo back' upgrade exhaust.
You'll want to replace the front/dump pipes if yours are standard.
If $$ is an issuea (which it was for me), just get an all in one front/dump 3" from flying performance www.flyn.com.au or something similar.
hmmmm.. . . . . . .
True if you're looking at brand new althought there is/was? a 2nd hand GCG high flow in the for sale in the last few days for $1350 i think and i got my HKS2535 delivered for $1200 from Japan (plus extra expenses on that one though for line etc)
For me, I'd go the 2nd hand GCG over a new Slide but that's just my personal preference.
Yeah Its just the standard dump I have, I have the 3inch Jasma front pipe :/ I will get onto replacing it. Whats better? 2.5Inch split ebay stuff or like a 3 inch single pipe exhaust shop job??
I can never remember which bit is which , front and dump. :/
Do a ring around some zorst places and ask how much to replace that piece then make your own decision.
Yeah will do. Ps dump is right off the turbo front is from dump to cat
  • 2 months later...
Sorry to bring up an old thread guys,
but with this set up - what injectors do you guys use? or what to reccomend?
Ive got the slide hi-flow with other mods like powerFC,EBC, walbro fuel pump
Only thing now that is restricting me is the AFM and injectors
Reccomendations guys?
Cheers,
Chris :)
i have had a slide highflow on my 33 for about 8,000ks now,you can feel more power straight away,but you diffnately need a aftermarket ecu,i have only got the stock computer in at the moment,will put one in soon hopefully,with my car being auto,need to look for a computer that can run the autos well.also will get a high stall,fuel pump etc,but the car and the turbo has good potential to run a low 12sec or even a high 11 second pass,no doubt :P
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
