Dont know how much interest i will get in this as not sure how many ppl actually have the demo?
But me an my mates have been going hard out usin both the Ferrari F430 & Porsche 997 T - all assists off and manual transmission.
Good fun, if anyone is keen post ur times up. my best so far in the 430 is approx 59:400 and in the 997 T 59:700.
ill get the exact times if i get some interest.
https://www.sau.com.au/forums/topic/170359-forza-2-demo-challenge/
i'll have a bash tonight and see how i go.
ABS off as well?
Yes ABS off too, absolutely no assists
Yeah, I'll take ya all on. I need more practice though, havent played it much.
We should have a SAU race in the full game on Live when it finally comes out.
Sounds like a great idea.
Ill post my exact times up in a few hours
i got like a minute flat in the ferrari no aids or driving line. that was on my final lap of the first race. then i got bored and did something else.
i'm keen for a race though when the game is out next month.
Well i'm already well into the real game, not the demo... but you get that!
Although i only spent the arvo on Sunday playing it.
Pretty good overall, some of the additional stuff is awesome, not just the racing itself. You'll see what i mean when you play it.
But there are some really annoying things that it requires, i hope they are features that open up later, otherwise endurance races are going to be absolute heartache to complete :D
But there are some really annoying things that it requires, i hope they are features that open up later, otherwise endurance races are going to be absolute heartache to complete :P
How did u get the full game so early?
Ye pretty good.
As with most of them, you can customise the set-ups end to end.
Engine swaps are a good thing as well. But then you need to spend ages getting the car setup right due to the big change in weight/power etc :)
Ive got the full version and am up to level 35 after about 40 hours play time. Damn its going to take some time to complete this game.
Yeah its one awesome game.....
Love to get the steering wheel.
Love to have 4 xboxes and 4 tv's and connect them all together to play the side views all at the same time
Negatives:
+ Game is too easy (even on hard AI)
+ Not many tracks (and lost of old ones from the first version)
+ Can not stop playing it.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
