Well as some of you know I had problems with my car losing power then kicking back in all of a sudden. First we thought electrical, but the mechanis said no, then the fuel filter...but apparently not.
Complete auto here in Whyalla is where i took it. They serviced my car, changed alot of piping and some other random junk. Costing around 700. They rekon they fixed the problem with what they did.......but they didnt. Now the rekon it could be the knock sensors i think they said, anyways they said theres two of them in my car. And they want to charge 1grand EACH!!! Lucky for me it was dad who has been paying everything.
Anyways dad's taking it into adelaide this weekend so hopefully somewhere there can help with the problem. Is 2 grand too much? AM i getting ripped?
Thanx >_<
Edited by Whyallapunk
https://www.sau.com.au/forums/topic/170416-pricing/
i think you're being taken for a run. sounds like they have no idea what they're looking for and simply changing whatever they think needs to be replaced.
diagnose your problem at a reputable mechanic - do it first time, do it right.
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3147512
FAAARRRHHHKKKK
for that sort of money, take it to an RB specialist tuner
much cheaper :/
and um, i was under the impression Non-turbo's didnt have knock sensors???
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3148173
  • 4 weeks later...
Thanx :cheers:
Howdy, this was a while ago but incase you check back here, where did you end up taking it in adelaide and how did it go? I'm in adelaide looking for somewhere to go for an N/A R33 service and some brake pads/gearbox work.. but all I have at the moment is a few places I know to avoid, nowhere recommended.
Seems either you go to a regular garage who is cheap but has no idea about skylines and cocks it up, or you go to a specialist garage who charges like you've got bottomless pockets and doesn't necessarily do the job any better unless you happen to know them.
There is a genuine nissan garage near my place but they quoted nearly $500 just to replace the front & rear brake pads. :D
With genuine nissan pads no doubt, i'm more keen on something aftermarket thats decent and reliable and costs alot less.
Any suggestions? must be some SA ppl here with some idea's..
Cheers
https://www.sau.com.au/forums/topic/170416-pricing/#findComment-3192920
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
