In a recent rego inspection i was told of a couple of problems i have to fix. Most of them i have covered but there's a couple that have me stumped.
Firstly, engine mounts have to be changed. Car is an R32 GTS-T. Is this a hard job? Am i right in thinking the whole engine doesn't have to be copmletely removed?
Secondly, leaky sump gasket. Can this be done with engine and crossmember in place?
Also, as far as i'm aware there is no actual gasket, its a chemical sealant. Would Permatex Ultra Grey be the right stuff for the job?
Cheers guys
Simon
Cheers guys
Simon
Simon did they give you a reason why the engine mounts had to be changed eg: they were cracked???
To change them you will have to lift the motor up (shouldn't have to come right out) along with the box using a crane and change them over whilst its up.
You can get to the sup easy enough with the car on a hoist and x-member still in place or with it up on jack stands :D
GMB
They gave no reason why they need to be changed. I haven't had a look yet but if i can't see anything obviously wrong with them then i'll try and avoid changing them.
As for the sump... that's good news! :D Any tips for doing the gasket? I never had to do one with a sealant before... only ever used gaskets.
If the sump has been leaking, it's possible the engine mounts have been affected by the leaking oil.
I suspect you are going to have to lift the engine a bit so you can manoeuvre the sump around the oil pickup. If you've lifted it up (and disconnected the mounts), may as well replace them.
Probably the most important point is that the surfaces must be CLEAN. So lots of clean rags and gallons of metho. And a tonne of patience.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
