I've got a rattling noise coming from the engine somewhere (seems to be low-down, not in the head) that disappears as the engine warms up. At first I thought it might be the cat, because I had a similar rattle in my Commodore and it was the cat, but that noise didn't go away when it got hot. I tried muffling the cat with a towel anyway just to make sure but that didn't make a difference.
It's hard to tell whether the noise is coming from the front or back, but my current theories one of the timing belt pulley bearings or maybe the clutch thrust bearing. I'm not sure if either of these noises would disappear with the engine warming up though. I don't think it's anything too far into the engine because it doesn't sound muffled by anything other than the firewall and bonnet.
Has anyone got any ideas?
https://www.sau.com.au/forums/topic/17076-rattling-noise-when-cold/
Have you got an A/M zorst?
I've got a similar rattle in mine, turns out it was just the bracket on my Apexi N1 rubbing against the factory rear exhaust mount.
I shift the rubber hangers around until the mounts have a bit of distance between them and it's fine for 4-5 weeks. Then it's time to move them again.
Yes, aftermarket exhaust. I guess that's possible, it might be something rattling on a flange and then as the metal heats up it kind of "seals" the gap so to speak. The noise isn't getting any worse (been this way for like 6 months now, maybe longer) so I'll get the workshop to take a look when I upgrade the dump pipe in a month or 2.
  • 9 months later...
Hi JimX,
Did you ever solve this problem? If so, what did you have to do to fix it?
Thanks Mate,
Brad.
Jeebus, NOW you're testing my memory. Let me think.... Oh yeah, I remember now. It was my wastegate (internal). The pivot was borked due to having been welded shut at some point by the previous owner and then cut open again. The result was that it was sticking and not closing all the way when cold and rattling. I got it repaired at Garrett for around $150 (I removed/replaced the turbo myself), after which the noise stopped and I also noticed a power increase because the wastegate could then shut more easily and properly.
I did have another rattle more recently, this was due to a blocked lifter. I spoke to a guy at Autobarn who also owns a Skyline, asked him if he heard of anyone having problems with Motul oil, which I had just switched to. He said no, but asked if it was my first sump full of Motul. I said yes, and he said to his co-worker "What happens on the first oil change with Motul?" The guy said that you get a lot of blow by and a really dirty exhaust, as the Motul cleans out the old crap that was in there because it's got a lot of detergent in it. That's exactly what happened so it wasn't really the Motul oil to blame.
The car's running fine now. I have switched to Fuchs for now, because it's also meant to be a "clean" oil like Motul and Mobil. Apparently Fuchs make a lot of synthetics for other companies too and they re-badge it. I'll try Motul again if I have any problems with Fuchs.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
