LI-11-NE for sale
Description
Immaculate 1997 model with 85000 kms, first owner in australia, complied in october 2006
Serviced every 5000kms, mechanically A1
Paint and interior are both very clean and in good condition
Timing belt has recently been replaced
Custom Plates LI-11-NE included
Recently replaced air-con compressor and had air con system tested, all works perfectly
New tyres all round
Just had minor service done
Mods
Cat back exhaust
Turbo timer
Doors are sound deadened with dynamat extreme
Clarion head unit with amp and splits for the front, 6 inch speakers running off head unit in back
The car is currently being sold at National Car Connections on Paramatta Road, just outside the entry to the markets at Flemington. (Near Homebush, NSW)
The price is $13990 ono
Edited by understated
pics? and what colour, any mods?
Its silver, the only mods are an NS Giiken cat back exhaust and a turbo timer. The doors have had dynamat installed, and the stereo consists of a clarion deck, 2 channel amp for splits in the front and 3 way coaxials in the rear. I'm waiting for some daylight to get some decent pics.
very interested, main problem is im up in brissy, but its only a 10 hour drive. it will only cost me bout 200 in fuel there
i dunno its a long shot but its exactly wat im looking for.. as long as its pretty much stock, clean, unthrashed
pic me up pls [email protected]
I've sent an email your way.
Cheers,
Jason
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
