Lighthouse - no.
North/South Beach - no.
Robertson Pie Shop sounds cool. Can go up Macquarie Pass and down through Jamberoo. Great driving roads.
Again, I'm not keen to cruise with dickheads. It's hard enough to drive these things without getting attention as it is let alone travelling in a group that appears to be hooning.
+1
meet somewhere like albion park rail maccas then cruise up?
  • Replies 114
Posted Images
  • 4 months later...
  • 3 weeks later...
anyone else have experience wif WAS?
My white R33 is currently sitting in the workshop of WAS.
Kon is a great bloke. Just don't expect to rock up and have it booked in for the next day for things like tunes etc.
He's great, but busy!
Does top notch work too...
PS: i'm from Wollongong, but it's been around 8 - 10 months since my Skyline has graced the roads of Wollongong (Other then a 10 minute stint up the freeway a few weeks ago)
Whats yours getting done there?
I drove past the other day and just saw commonwhores so was a bit turned off.
It's in for a full tune.
Plus oil flush, coolant flush, and a few other things like a few PS lines changed.
Currently it's at the state if you can get it to start, it'll barely idle, won't rev much at all.
I KNOW I won't get a phone call, until it's basically driving like factory
I've given up on servicing my car now-a-days, I just can't be bothered jacking it up and doing all the shit, that it'll be going to WAS for everything from now on.
Kon does work on a lot of Holdens and Fords as he loves V8s, BUT if you go by enough, you'll see those Holdens and Fords being challenged for numbers by the WRX, Skylines, and other imports.
He deals in them all, and his quality of work is TOP NOTCH.
I just moved to Kiama last week, would be good to organise a cruise and meet some sau ppls..
Does anyone know any good workshops in the area for general servicing?
Cheers
Johno
I'm interested in a cruise this Sunday. Be good to meet at Kiama Leagues Club car park, an maybe go for a cruise to Gerringong or ????. open for suggestions.
Ive used Screamnperformance at Fairy Meadows and if you dont mined the drive JEM @ Ingleburn 45 minutes from the Gong
cheers
Yeah im from the Gong also.
Bezerkly was my choice but just do most work myself now.
Ha ha ha, I went the other way, used to do everything myself, now I just can't be f**ked jacking the car up after the conversion, so I just pay Kon @ WAS now to do it all.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
