Hi Guys,
Basically bought a Z32 AFM new, i put it on my car only to discover i needed a bigger one (Q45), so its done 4 or 5 runs on the dyno and basically in brand new condition. There is a plate that was made to bolt on the front of it that suits any 3" POD Filter.
Price is $250
I have a Brand new Hi-Tech Exhaust System to Suit R33, Full 3" Cat back system (Cat is High Flow) to a stainless tip. I also have a dump pipe brand new, to suit a T04Z Turbo (will fit some others not sure which though) which is for sale with or seperate from the exhaust. The exhaust has never been used, i had it bolted up to the car and then decided to tear the motor out and do a RB30 Conversion so its no longer suitable for the power im going for. The system is very well made, sits really tight and flush to the underbody of the car and has great ground clearance.
Chasing around $700 for the system neg. $150 for the Dump.
Also for Sale -
2 Sets of Mirrors - 1 x Black and 1 x Orange (Pics to Come) $100 Pair neg.
1 x Set of Standard Cams to suit S1.5 / 2
1 x Set of Standard Coils to suit S1.5 / 2
Items located in Brisbane. Will Quote postage at request.
Edited by Got Boost?
Would rather keep it together at this stage, unless i can find someone to take the other section. If anyone wants to make an offer on something also please do.
  • 3 weeks later...
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
