I know its a real battle Dave but tell them they should still come along. I know its hard to try and find a way to contact everyone :domokun:
I know allllll about it!
I can tell you of a place with sweet sweet candy :laughing-smiley-014:
Is there a bridge? And a magical leoplurodon?
  • Replies 152
well we're probably driving down on the sunday now instead of going down on saturday so we might see you somewhere along the way ( when you overtake me in the freeway lol )
No we'll wait for you. :( Are you going to meet us at the Twin Servo's at Wallsend? If so come and see me and I will give everyone a copy of the directions on the morning, incase we get split up. I'll post them up too in here.
no its ok cos i live in valentine and picking someone up on the way through swansea.. and besides i'll be in my charade lol
if anyone need me to carry anything my stag will have room, i feel left out coz brycey is carrying everything
Where do you live? I can drop some stuff off for you to take so you dont feel left out, I have heaps of stuff to take.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
