Item: 19 x 9.5" Work KH wheels and tyres with +30 offset to suit GTR
Condition: Excellent
Has 265/30 Pirelli P7000 tyres with 50% treadon rear and
NEXEN SILICA TYRES 235/35ZR19 strecthed on the frotn brand new never driven on
i got these of NXTME on these forum they are a beautiful wheel one of the best wheels i have seen all balanced and tyres on
these come with small 6mm spacers to fit on a r33 gtst need to roll the guards and the rears pumped out a bit
im after a swap or a out right sale i have a r33 gtst i just wanna get it back on the road
im aksing 2,500 2,200cash without front tyres very firm as i just put new tyres on them these rims are huge
Edited by teazn_r33
nice wheels. so they would go on a r33 gtst? only have to flare guards yeah? did you really get offered 2000 for them???
ok interesting, i have a set of 17inch volk racing rims at the mo, nice wheels, rare style, looking at bigger... how much would it cost to get them freighted to tassie 7140?
i have no idea about freight to tassie you might be able to help can u please send pic of wheels if you look to swap im sure for the right price i could arrange freight but you might nee to help as there is alot of water between us lol
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
