post-30145-1181117631_thumb.jpgpost-30145-1181117848_thumb.jpgpost-6787-1123677378.jpgpost-30145-1181117799_thumb.jpgpost-30145-1181117746_thumb.jpg[
ttachment=102290:DSCF0214.JPG]post-30145-1185446017_thumb.jpgpost-30145-1185446073_thumb.jpgpost-30145-1185446231_thumb.jpg[at
achment=110652:DSCF0238.JPG]post-30145-1185446566_thumb.jpgpost-30145-1185446485_thumb.jpgpost-30145-1185446566_thumb.jpgpost-30145-1181117631_thumb.jpg[atta
hment=102289:DSCF0213.JPG]post-30145-1181117696_thumb.jpgpost-30145-1181117746_thumb.jpgpost-30145-1181117923_thumb.jpghey all,
up for sale is my 1993 nissan skyline gtst m-spec, with 128587 kms.
SERIES 1 1993 NISSAN SKYLINE
THIS EXAMPLE HAS THE FOLLOWING PERSONAL MODICATIONS:
JJR JUST JAP FMIC
JJR JUST JAP 3" FRONT DUMP PIPE
HI-FLOW CAT-CONVERTER
3 1/2 "CAT BACK EXHAUST INTO DUEL TIPS
HKS AIRPOD
HKS TURBO TIMER
HYBRID 2 STAGE ELECTRIC BOOST CONTROLLER
(LOW BOOST 7 PSI, HIGH BOOST 10PSI)
18" XHP SHIFT IN GUNMETAL GREY
BRAND NEW TYRES 225'S AT FRONT 235S AT REAR
(25 KMS ON FRONT AND REAR TYRES PURCHASED 05/06/07)
PIONEER MP3 CD PLAYER AND 12'SUB
COUSTIC 150RMS AMP
PIONEER REAR 6" SPEAKERS
KENWOOD FRONT SPLITS
REPELLER TOP OF THE LINE ALARM SYSTEM
(REMOTE CENTRAL LOCKING, ULTRASONICS AND IMMOBILSER)
HALF GOLD CROME WINDOW TINT/HAlF DARKEST LEGAL TINT
SLOTTED FRONT ROTORS
BENDIX ULITMATE BRAKE PADS
FULL SERVICE JUST COMPLETED
TIMING BELT CHANGED 105,000KMS
BOOST GAUGE
10 MONTHS REGO
ALL WORK AND SERVICING WAS COMPLETED BY NPB (NORTHERN BEACHES PERFORMACE, AS SEEN IN LATEST ISSUE OF HOT4'S WORKSHOP REVIEW)
SELLING DUE TO NEW COMPANY CAR.
AWESOME CAR LOOKING FOR A HOME. REGRETFUL SALE
WAS $12900
parking accident caused by other party has caused slight damage
scrape to the rear left bumper
slight crack in the rear tailight
golf ball size dent just to the left of the left taillight
still 100% driveable
will take 11500 with the damage repaired
or $10000 as it is
new pics shown above
regards
Dave
0423 321 221
Edited by MY33RT
https://www.sau.com.au/forums/topic/171692-sold/
