I have the follwing parts up for sale due to engine upgrade will post pic's asap.
rb20det motor & box comes with the following(motor has bottom end bearring noise) post-1686-1181483637_thumb.jpg
* forged pistons
*t3-t4 ford cosworth bush bearring turbo with 3inch dump pipe ,comes on boost about 3500rpm post-1686-1181483675_thumb.jpg
*larger injectors rated around the 380
*car had just over 220rwkw @16 psi
*gear box is in good condition and comes with used heavy duty clutch $1000 for motor ,box,turbo & injectors
*wolf3d version4 plug in for rb20 with handcontroler, boost control and other sensor's must go $1000 cost $1700 post-1686-1181483562_thumb.jpg sold
*full intercooler kit from avo $200 post-1686-1181482593_thumb.jpg sold
*19 x8 inch gold zenetti mags to suit r32 gtst offset good condition 2 with 95%tread 2 with 20% tread $1200 sold
Edited by chewy32
Hey, how much for the wheels?
Let me know as I am in wollongong NSW
and am on the hunt for rims.
Cheers.
P.S. If tax was here already, I would grab that Wolf.
Cheers.
mate, tell me about it i cant wait till tax time myself need some cash to finish mod's.
wanting $1200 for the wheels .
why is that?
is it because you have no idea on what car parts are worth to purchase?
or is it because you have no idea what a reasonable price is?
Didn't have any idea how much a second hand wolf was worth! I don't actually need one till the end of the year when the CA is built for the Datto, Just thought It might have been a bargain! Still a good price though!
Edited by boosted_sa
ah , no worries
so bottom end bearing is gone on the motor ? how many ks was on it?
everything i need to do a conversion into another car?
bottom end bearring is gone car still runs just noisy
it depends what car? auto manual? you get complete motor minus computer you also get box and clutch, no pedals no clutch master.
if you want for a extra 150 i can sell you my piggy back computer which is just a chipped standard computer that allows you to run more fuel.
Edited by chewy32
^ s13, its currently auto ...
youll need to get a pedal box & clutch master and a few other bits and pieces not sure exactly , if you can find out what it needs?
let me know and ill check and see what i can throw in .
Edited by chewy32
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
