Hey guys, bought a HKS SSQ BOV but ended up also getting a turbosmart one so i've decided to sell the HKS one
It has the purple insert bit which apparently makes it louder
Its 100% genuine no bullshit copies
$240 ono
I will also swap for audio gear or R33 parts so throw me some offers
Located in Brisbane
Pics
https://www.sau.com.au/forums/topic/171850-hks-ssqv-bov/
Hey, i'm after aftermarket parts like strut bars/sway bars basically performance parts i dont already have, i also may consider a aftermarket front grill to suit a s1 R33 and rear wing so throw me some offers
Cheers
Edited by burgO.
https://www.sau.com.au/forums/topic/171850-hks-ssqv-bov/#findComment-3166993
Nar not after a s2 wing, cheers tho,
I dont have the adapter for a 33 but the weld on ones are $10, its better to put a bov on your intercooler piping behind the front bar so then coppers wont find it as easily, putting an atmo bov in the stock position is just asking for a defect.
I will have a blanking plate by the end of next week also which ill throw in for a little more if required.
Heaps keen to trade for a sub and amp atm!
Cheers
https://www.sau.com.au/forums/topic/171850-hks-ssqv-bov/#findComment-3168604
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
