Sold Out!!
yes I had 300 tires - all sold
No I do not work for dunlop
No I do not work for a tire shop
Yes I have a mate that I am selling them for, he got 400 tires and rims from last years XR6, has sold the rims, and 100 tires are not what I class as good to sell, maybe just for commodore drivers to rip up, thats about it. The remaining 300 have the small imperfections as shown in the photo, the sidewall is not damaged, and the tires are still road legal, they are factory seconds.
Hope this helps
Some have slight imperfections, as pictured below, nothing worse than this.
Edited by CrazY_J
https://www.sau.com.au/forums/topic/172064-sold-out/
Oi dude, can see ya lurking. How's about if I sort with Toll to pick up the tyres? All you gotta do is tie a bit of string around four of the buggers.
Can't be too hard. So, exactly what sort of Dunlop SP Sport are they? I've been checking and there are several different tyres under that heading, ranging from AP3000's to Maxx's. Which ones you got? Are they seconds or top notch?
https://www.sau.com.au/forums/topic/172064-sold-out/#findComment-3169634
What's Dunlop's policy on them? Still kosher for road use or are we on our own if something goes wrong? What about legality?
Yeah I've seen the pic. Just making sure my arse is gonna be covered before I think about parting with cash.
https://www.sau.com.au/forums/topic/172064-sold-out/#findComment-3169705
Are these the ones that commodores and falcons came out with from factory? If so im from sunbury and ill grab a set. thanks
Yep, that's the tyre. Rated for 270 k's and two and a half tonnes of taxi. More info: http://www.dunloptyres.com.au/TyreDetailAc...p;from=nPerPage
Here Crazy J, I'm doing your job for ya.You owe me some free tyres. :P
https://www.sau.com.au/forums/topic/172064-sold-out/#findComment-3169715
The imperfections were made by dunlops claw machine whilst picking up the tires, they are still road legal.
Your right, they came out factory on the XR6 last year, however not many were sold and therefore there are heaps of tires left over..rims already sold...
Edited by CrazY_J
https://www.sau.com.au/forums/topic/172064-sold-out/#findComment-3169722
Here Crazy J, I'm doing your job for ya.You owe me some free tyres. :laugh:
you just beat me to the post :P
https://www.sau.com.au/forums/topic/172064-sold-out/#findComment-3169723
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
