I put mine where the abs is supposed to be. I'm assuming you have a S1, so most likely you won't have abs therefore there is a rather large cavity to put 'whatever' into.
If not and you do have abs, then most guys find some room towards the front of the engine bay beside the radiator somewhere.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
