Hey guys, I'm basically im upgrading.. looking for about 270-280 kws which this turbo cant make..
Turbo comes with custom RB25 T28 flange exhaust manifold, oil & water lines.
Turbo has been on car for 2 years now and was only boosted to 14 psi 3 weeks ago.. before that was only on 9-10 psi
since the motor didnt have a fuel system...
Its good for up to 220 kw's on a very accurate dyno, not a happy/sky high reading dyno.
Turbo is very responsive, is at full boost by about 3100rpm & rips all the way through..
This unit would also work VERY well or better on an RB20 or SR20 but still good for an RB25!
These retail $1900 new, im just after $1400 (negotiable) with exhaust manifold & lines to go straight on!!
No pictures as yet since its still running on my car, once i recieve some form of a deposit or something will get onto removing it immediatly.
Please PM me or call me on 0401 682 270. If u pm me please leave a number so i can call back to make things easier.
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/173006-turbo-garret-b-bearing-gt-28-76r/
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
