hey guys...
i'm hoping someone on here might be able to help me...
i've done a search, but i cant find a thread with my problems...
its an RB20DET with fmic, 3" exhaust, fuel pump, t04e (brand new), splitfire coilpacks and irdium spark plugs... STANDARD ECU
basically, when i do a cold start it PISSES out white smoke (smells of fuel not oil) and it misfires on idle... but if you rev the car, the misfiring goes away but there is still craploads of white smoke coming out the exhaust...
but then as soon as you take it for a drive and the engine temp comes up to 'normal', all the smoke clears away (apart from a bit of black smoke cause its running excessively rich) and the misfiring stops on idle...
now.. i'm completely stumped as to why this would be happening... does anyone have any suggestions on what it could be?
i cant see it being a blown head gasket because a) the smoke clears up once the temp comes up to normal, b) the water in the radiator doesnt have a flim of oil on it and c) the oil isnt milky....
i believe i have two seperate problems... but they could be related, i dont know...
the first problem is that its running REALLY rich and i believe thats why the smoke smells of fuel and possibly why its misfiring because the spark plug is getting wet from too much fuel... sometimes it sounds like it running on 4cyl and other times it sounds like its running on 5cyl...
then the second problem is the white smoke which i have no clue on...
PLEASE HELP!!! i cant go on like this... :P
if you need to ask any clarification questions, then go ahead... ;)
thanks
ash
https://www.sau.com.au/forums/topic/173061-misfiring-and-white-smoke/
Still can be a head gasket :P
You may have a minor crack that leaks into the bore, when cold, then as the engine heats up everything expands and seals up, till it gets cold again. If a gasket leaks water into a bore, the water will never mix with the oil, or vis-versa, and the water will then pass through the exhaust system.
All cars have white smoke in the mornings, but it really depends on how much you consider alot.
I am by no means stating that you have a blown head gasket, just advising that it is still a possibility and should not be ruled out because of the things you have listed.
Easy, White smoke on cold mornings here in brissy at the moment condensation, missfire due to running either colder plugs say 7's as they take a while to come to temp or the excessively always running rich fouling your plugs
Done :P
There is a sensor for cold starts it might be stuffed
Have u ran the diagnotic on the ecu it might tell u what is wrong
good point, thats one thing we havent checked... didnt think it would cause all the smoke... :whistling:
Still can be a head gasket :yes:
i was told this by someone else today as well... i had never heard of this happening before... i didnt know the HG could have a 'minor crack'... i just thought that once they go, thats it, its gone!!
i call it "A LOT" when you sit in the car and you cant see behind you because of all the smoke...
Done :)
when i say "cold start", i dont mean just in the morning... it could be at 2pm in the afternoon... i just mean that it hasnt been started in quite a few hours so the engine is "cold"...
and its not condenstation in the exhaust system... my euro 'smokes' in the morning as well which is caused by condensation in the exhaust system... this is thick white smoke that bellows out of the exhaust pipe...
after all this, it was started today and driven back to my house from my mates workshop and there wasnt a puff of smoke at all and absolutely no mis-firing... so it seems like one day it will smoke and misfire, then the next day it will be fine, then the day after that it'll have problems again... :P
could a minor crack in the head gasket 'come and go' like that?
and would a minor crack in the head gasket cause it to misfire randomly at idle?
i'll start her up in the morning tomorrow and see if she smokes and misfires or not... :)
thanks for the suggestions guys... please keep them coming.. its greatly appreciated! :)
well, the smoke and misfiring is back today...
it kinda sounds like its choking on something on low revs, until you stab the throttle and bring the revs up then it clears up until the revs drop again... :?
any ideas from peoples??? :whistling:
it sounds like you might have a leaky injector hence the running really rich, i cant say i have seen white smoke from fuel but it may be possible that the plugs are not burning it all and is getting onto your turbo and doing something odd with the seals, i had this problem with a silvia a few years ago.
easiest way is to remove spark plugs, unplug ignitor pack, then prime the fuel pump, if you can see fuel in any of the cylinders you have a leak. now it could be either the injector itself or is could be one of the o-ring's that seals then into the fuel rail.
How about valve stem oil seals??
is there anyway of testing that without pulling the engine apart?
i havent had a chance to start the car since my last post... been too busy with work... :O
i'll update on saturday when i take it for a drive... :)
I actually started to think the same thing, but didn't come across this thread again till now.
okay...
any idea on how to check them?
or is it a job for the mechanics to pull the engine apart?
edit: just thinking about it again... would the valve stem oil seal cause BLUE smoke??
i dont have any blue smoke.. its only white... ;)
Edited by S13 SecaBoy
my issue is this...
IF it was using water, then straight away i'd point at the BHG... but its not using any water... :cheers:
IF the smoke was blue, then it'd point to an oil related issue... but the smoke is not blue and its not using any oil...
i'm gonna pull out the spark plugs and see if there is any fuel going into the cylinder with the car off...
firstly though, i'll check to see which cylinder is dropping out... that way i dont have to take ALLLL the spark plugs out... :D
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
