I found this quote on bendix web site.
We recommend that rotors are machined only if they exhibit disc thickness variation (a shaking steering wheel and/or pulsating pedal on brake application), severe scoring, runout or heat checking.
I am going to change my rear brake pads soon. I am not sure if my disc need to machine or not?
How do I know if I need to machine the discs? Can I judge it by see it and touch? maybe shiny and smooth?
Thanks
https://www.sau.com.au/forums/topic/17346-brake-disc-need-to-machine-or-not/
my discs started to go on me recently, but a very good friend of mine who tunes skylines and other high performance vehicles strongly suggested that i replaced them not machined them, the discs start to get really shinny and have like a glossy look on them, i replaced mine with slightly larger ones.
i just changed all 4 pads today and had the disc machined also. the rears were very noticable as u could clearly see where the metal indicator was rubbin on the disc's......it was bumpy and uneven. i guess u can tell by lookin and rubbin ur fingers over it. the fronts werent as bad but i had em done anyways. i think they also help aviod that squeakin problem. its a cheap alternative but if u have the dosh change em like 2BNVS did.:D
My old stock rotors were machined twice before i replaced them. Machining them is fine until their is nothing left to be machined. If you replaced your rotors instead of machining them you'd be up for rotors once a year.
  • 5 years later...
Sorry to bump an old thread, but didn't want to start a new one.
My brakes have been shittin' me for the past few weeks.
After braking at speeds of above 60ish the brakes will make a sort of creaking noise and the steering wheel will kind of shudder a little with a bit of noise.
Am I right in assuming I definitely need to get my rotors machined?
Edited by ray32
Same boat as me, when hitting high revs going at 70 or 80 and trying to break, they dont make a noise but they start to shudder really bad, Need to bet them machined.
Got other pair of rotors sitting at home, theyre bigger, and dunno if they will fit.
:D
MRXTCZ
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
