VOLK SE37k bronze (forged rims) very light
have these rims spare. cant exactly remember the offset of the rims but theyre somewhere between +30 - +40
rims are in pretty good condition few minor scuffs,
they have Hankook K104 235/45/17 all round, alot of tread left.
price $1300
can sell less without tyres
im in no rush to sell as these, they are a spare set that i use from time to time.
they would suit a repaint looking up close.
but from a few metres back they look fine.
detailed pics below
http://members.optusnet.com.au/stryder2/
Edited by k3
https://www.sau.com.au/forums/topic/173496-rays-se37k-sold/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
