Custom Lock bar for R33 Skyline
The fabrication company made 3 additional lock bars
Price and Payment Conditions: $150
Extra Info: Replaces standard Hicas system with heavy duty lockbar (bolts straight up and has alot more strength than a standard lock bar)
Contact Details: Post or message
As Below you can see the comparison in the 2 lockbars, if you want something that may warp or bend under pressure by all means go the cheap option. The one that is for sale is the top one which won't warp or bend under sideways motion.
Lock Bar which is for sale:
Cheap Lock Bar:
See the difference,
I've had it on my car for a couple of months and it has made the handling of my car totally different to what it used to be, especially driving over 100km/h. It is worth while modification to your car whether it has coilovers or not.
Edited by HavnFun070
https://www.sau.com.au/forums/topic/173695-lock-bar-for-r33-skyline/
I've hit a wall at 140 with a "cheap" and no problems. Granted that was an airbag, but it still did a fair bit of damage!
About a year of track driving with mine, drifting, circuit, semis, road tyres.
Yours does look very good quality though. I assume spherical bearings in the inner joints?
Edited by salad
  • 3 weeks later...
I have talked to the manufacturer and yes they are.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
