i take it you have had a good look at the damage... does it run? what happened when the bolt came loose? i assume its going to need an entire rebuild...
I dont think it will but I guess wont be able to tell for sure until the oil pump and sump are changed and I try starting it
https://www.sau.com.au/forums/topic/173730-delete/#findComment-3193220
picks of damage from when it was broken into-
[email protected]
its all been fixed now...
just the passanger side mirror is hanging cause the bracket thing that holds it broke...
https://www.sau.com.au/forums/topic/173730-delete/#findComment-3193850
