I've read a couple of things about why HICAS lights come on (power steering fluid low, alternator gone, HICAS dead), but my situation seems a little different.
It comes on when I cold start the car, and once I've been driving around for about 15 mins it switches off. Then it'll come back on only if things get a bit tail happy or traction is lost. Otherwise, it seems to stay off.
Is this normal?
Is this normal?
do you have an aftermarket steering wheel and Boss kit because this can cause problems if it isnt all alligned up
The steering feels normal and my wheel is completely stock. Same with the suspension.
It does go off after about 15 mins of driving tho and only switches back on if the wheels spin - but goes straight back off once there's traction again.
mines been doing exactly the same,but i warm mine up for 10minutes,so
the light goes off sooner,i put it down to cold fluid.
not sure about when the wheels spin as im looking where i want to be going
this has confirmed my decission in removing hicas.
i been reading all the hicas threads for months and its just easier to get rid of it
NV_NO1 sells the lock bar for $70
im just finding someone to remove it for me now.
how is your speedo needle, does it boogie?
it actually does sometimes. today i also noticed i was doing 180kmh at 2500rpm in 3rd gear. then it went back to normal. weird =S
i might just invest in a lock bar in the near future.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
