This is an excerpt from the G35 2003 ESM that also applies to the V35.
It outlines what maintenance and preventative inspections are recommended to be performed and at what intervals.
ma1.pdf
Edited by -= SKiZO =-
https://www.sau.com.au/forums/topic/173808-maintenance-schedule-for-the-v35/
No worries, not sure if many know about this new v35 forum though so maybe we need to advertise! From the time I decided to change cars till i actually got it in my hands was about 6 months, so spent that time researching as much as a i could, i guess in a way to confirm that I really wanted this car. But so glad I did get it. I get the info from lots of places but alot of it comes from g35driver and the US guys have been really helpful.
  • 3 weeks later...
There is a folder on g35driver.com with the whole manual. This is the link for people to download:
2003-2004 G35 Coupe BOTH Automatic and MT Transmission
http://rice.sightless.net/03-04coupe.zip
2005-2006 G35 Coupe BOTH Automatic and MT Transmission
http://rice.sightless.net/05-06coupe.zip
  • 1 year later...
My maintenance is due and read the guidebook. It says to replace the in-cabin microfilter. Sounds like it is unnecessary. Has anyone ever replaced it?
changed mine last year. you can get it from a nissan dealership for around $110 and replace it yourself - it's a pain to do it though as you have to remove a lot to get to it. it's way cheaper if you can get it from the US, i think it worked out to be about A$25 including shipping to a US address. not really necessary to replace it but it can get quite dirty after a while and a dirty filter can give off a bad smell when you switch on the aircon.
I know it is a little old but those files do not work, is there any chance that you can update them...
Perhaps if you have a copy of them you could upload to www.megaupload.com, it is free for basic use!
Would be a great help if you can assist.
They get really dirty quickly and clean air is so lovely. There are normally pictures of how they look at Nissan Delearships, they are not unlike a standard paper filter but they are treated for microbiological contaminent particle trapping.
I took a look quickly at G35 and there is a link to a website that you can download lots of different manuals, unsure of the actual quality as I am still downloading.
This is the site and everyone should take a look...
http://psedog.com/cars/fsm/g35/coupe/
Use the links on the side for different cars.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
