I've heard good things about Mickey Thompsons. what size are you looking for?
A lot of the muscle cars (Trans Am's, Vette's, Mustangs etc) around here use the MT's and they seem to do pretty well. I think that personally I would go with the Nitto's though. Can't say that I've ever heard anything bad about either ones, and from what I've seen/experienced on my own, they both offer crazy grip. Just don't get picked up by the fuzz with slicks on your car. Even the 'street drag' tyres are pushing the limits of legal.
https://www.sau.com.au/forums/topic/173933-tyres/#findComment-3195086
good in dry shyt in wet but the MTs you cant go wrong with just take bit extra care in the wet, or have a look at something with good temp and soft compound and your set, but comes down to crap in wet most of them and also they wear pretty quick
https://www.sau.com.au/forums/topic/173933-tyres/#findComment-3195120
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
