details....um ok :D
how does this sound:
Date: Saturday 7th June
Time: 2pm
Place: National Library carpark
Itinery: Cruise around the Lake, go up Mt Ainslie for a photo opportunity, cruise back thru Civic to Belconnen, have a late lunch/coffee at Zefferelis near Belco Mall.
Whole cruise should only be a couple of hours, and ppl can leave the cafe whenever they want (if they need to take off early or whatever).
Sorry for the late notice, but everyone please come along and say hi to Kamikaze! If it's a nice day we should get some good photos up Mt Ainslie too.
see you there!
Shell :)
https://www.sau.com.au/forums/topic/17409-cruise-7th-june/#findComment-360917
No snow Jay... but fcking close to it...
can't believe how cold it was down by the lake...someone remind me why I haven't moved to Brissy yet????? :)
thanks for coming guys, wasn't expecting such a good turnout! Sorry about the cafe not being open...but Pizza hut wasn't so bad as a substitute...I was so bloody hungry I didn't really care where we ate really :)
anyhooo...my pics are here
Justin, hope the trip back home today went ok and u didn't cop any double demerits! :)
https://www.sau.com.au/forums/topic/17409-cruise-7th-june/#findComment-367778
Well done with the photos Shell.
If i'd known you were doin sneaky ones out the back window i mighta put on some doorifto for the viewers.
I still managed to scare shit out of a taxi driver and his passenger!
We really need to find a good long fast drive next time, I had to go down to Jindabyne and back on Saturday night to blow the cobwebs out.
Enjoyed meeting you all and looking forward to the next one.
https://www.sau.com.au/forums/topic/17409-cruise-7th-june/#findComment-369788
Hey Shell, great pix, good to see some of our youngest members in there too :D
If I manage to get a slightly older (and taller) passenger along next time, I'll try and get some video as well as pix to post up...
Hey Drifto, great to hang out with you guys...can't wait till the next time we get to have a bit of a go (beats the hell out of the day to day traffic runs :( )
We definately have to do another cruze down Kangaroo Valley or somewhere similar...
https://www.sau.com.au/forums/topic/17409-cruise-7th-june/#findComment-370510
hi drifto...Damo took those ones out the back, we tried for some out the side window too but couldn't get a good shot ;)
maybe we should do a run to Jindabyne one time! that would be pretty cool actually. Not on a double demerit weekend though :(
James...she's such a cutie!!! ;) ;)
SAU's youngest mechanic...
https://www.sau.com.au/forums/topic/17409-cruise-7th-june/#findComment-371138
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
