  • Replies 40
Hey mate, Missus is interested in your 32. She's after a swap, so depends what you are after really. She's got a 98 VS Commodore Ute 3.8V6 5Sp Manual. 22,000kms (recent rebuild) with receipts. Electric Windows, Leather Seats/Doors. LSD Diff. Tow bar, Darkest legal tint, Mags with 95% Rubber, JVC Stezza with amp and splts, polished roll bar, Lowerd, Very reliable. RWC and $1000 Cash.
https://www.sau.com.au/forums/topic/174206-mod/page/2/#findComment-3365869
Hey champ. chucked in my bike with the deal (CBR250RR). anyway, free bump aswell.... but now its the bike and ute that i want to swap, lookin for a 32/180/200 import
98 3.8L V6 Ecotec (freshly rebuilt with receipts 22,000kms)
5Speed Manual
Leather seats/Doors
Power windows/Mirrors
Tint
Stezza
Tow Bar
Chrome mags with bran new tyres
Alloy roll bar in tray
Serviced before or on 5000kms
CBR250RR (55,000kms)
Manual (Obviously)
Fresh BMW Black with red metalic paint
Serviced every 5000kms
Forks just been rebuilt, new disc's front and rear, braided lines, new pads. Just had tune/service
Looking to swap for a Skyline/180/200 thanks,
Tara
https://www.sau.com.au/forums/topic/174206-mod/page/2/#findComment-3372398
5Speed Manual
Leather seats/Doors
Tint
Stezza
Tow Bar
Manual (Obviously)
no thanks .. dont have bike licence either
cheers
https://www.sau.com.au/forums/topic/174206-mod/page/2/#findComment-3373330
need more detail and some pics
cheers
91
white
sedan
CP pistons
ARP rod bolts
Prepped stock rods.
new bearings
97 TT heads
intake resonator removal pipe
modified stock air box and intake snorkel.
replaced Coolant header tank.
STI clutch
aftermarket lightened flywheel.
JAYCAR air fuel adjuster.
3" MRT dump/cat/front pipe (to halfway under car) and 3 inch mild steel from there back leading through a resonator and in to a 99 STI muffler.
All performance, with a little more sound over stock.
KYB damper adjustable and rebuildable shocks
lowered king springs to match.
whiteline adjustable rear sway bar.
DBA slotted disks with quality pads.
Engine rebuilt by perFOURmance motorsport.. look them up if you don't know them..
have receipts for over $5K on that alone.
Stock VF8 is bolted on and set to 13psi.
12 months qld rego starts in 3 weeks.
interior is clean and has had seat covers for most of it's life as it has now.
the usual drivers seat, outer edge is worn.
has tinted windows
pioneer CD head deck and replacement stock sized speakers.
rex seats only cost about $500 at most anyway.
The body has 316,000kms.
engine was rebuilt as a reliability precaution rather than a Necessity hence the stock turbo being back on there.
it was built in 2004.
Looks wise, it is a stock white Liberty RS that sits a little lower and has a towbar at the rear.
If you still want pics, let me know which parts in particular and I'll get some this weekend.
https://www.sau.com.au/forums/topic/174206-mod/page/2/#findComment-3373684
white
sedan
CP pistons
ARP rod bolts
Prepped stock rods.
new bearings
97 TT heads
STI clutch
has tinted windows
thanks for the info mate,
i'll think about it... cause it registered in QLD and it gonna be hard to get blue slip here in NSW to transfer under my name...
Cheers
https://www.sau.com.au/forums/topic/174206-mod/page/2/#findComment-3375518
I don't see why though.
all the rego numbers and engine numbers match.
it is still the original block that was rebuilt so no number changes.
Built to stock specs using better quality materials so compressions and capacity are all stock.
there are no defectable items on it.
All emisions stuff is still intack.
exhaust is well below sound levels.
Ride height is well above minimum.
up to you though...
https://www.sau.com.au/forums/topic/174206-mod/page/2/#findComment-3376541
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
