I have HKS coilovers in my car, but don't know the model, whether it is dampening adjustable, camber adj, whether it has poillow tops.
Where can i go to check which of these it does have, and what brand these are?
Also, can you "service" coilovers rather than sourcing new ones?
How much does this cost?
And it has these turning knobs above the rear parcel shelf. What the hell are these???
I only had springs in my old car...so new to coilovers.
Thanks!
https://www.sau.com.au/forums/topic/174503-how-to-check-coilovers/
Thanks!
usually dampening force is adjustable via turning pegs on the tops of coilovers. somethimes they are marked with lines and numbers. if you see something like this then they are probably adjustable for dampening force.
Thanks!
yeah... this knob u talkign about is ur damper adjustment. Click them all to zero (anti-clockwise) then click them all to say 10 and make sure they even or will ride like crap.
As for camber/pillowball tops. Camber tops are only available in Macpherson strut desings. Skyline does not have this (silvias do). You probably do however have pillowball tops (metal tops) Look under your bonnet at your coilovers.. or through the parcel shelf and there should be metal around that "knob" its probably purple/pink if its HKS. If you have this metal then congradulations u have pillowball tops. Realy only advantage of these are its a bit stiffer then the standard rubber/plastic tops.
Also if you jack your car up and take your wheel off and look at ur coilovers you will see a seat below the ring.. it is two seats holding the spring up. If you dont have any "C" Spanners then get a screwdriver and hammer and u can loosen them by turning them and adjust the height of the car. But make sure you clean all the threads befor you go doing this or they will seize up and get stuck.
As for servicing coilovers yes, yes you can have them serviced and it is approx $100-$150 each. Only do it if needed
cheers
Edited by choku_dori
bought my car prob 10 months ago and have always thought the coilovers are too loud....always wanted the to be checked out, can say pedders or beaurepairs look at them to check they are still safe?
always thinking im gonna loose a wheel or something....
Slight correction, pillowball tops are not refering to the strut top itself being metal, I havn't seen one that isn't metal yet...
If it referring to the fact that they use a spherical bearing/rose joint/pillow ball to locate the shock shaft to the strut top. For a street car, they provide lots of NVH and wear out quickly, then begin to knock once they start wearing out.
is it normal for coilovers to make clunking sounds from the rear?
like a shitbox with long gone suspension?
Cause mine clunks and rattles alot
Clunking sounds is a sign ur coilovers are way past its used by date. They are probably leaking. You can either get them reconditioned (https://www.shockreco.com) or buy new ones.
Reco is different to being serviced?
servicing = replacing struts, seals, regas etc... = rebuild. Costs around $150 per corner approximately from TSR in Brisbane.
$600 is cheaper than $1600+ so i guess i'll get them serviced
only if they guarantee no more clunking :P
does anyone know where car I get my Tein HR coilovers servicing or rebuild? i'm on the Coast NSW and dont have stock suspension ! do i need my car to put on stands when I do servicing or rebuild?
Cheers
I was talking to EastCoastSuspension.
And they said they can't service my coilovers (HKS) as it's imported...
Anyone know who can service HKS?
And as for u subie, i think fulcrum can service yours.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
