Brand New Tein Bonet Damper to suit R33. Selling for $200. I'll post pic ASAP. Initially need it for my 34, but it does not fit.
Its also for 33 GTR. not sure if it fits GTS-T I have approximate measurements in next few threads.. so you can check if it fits. The legth of the damper is no problem, its the spacing of the bolt holes, unless you are able to custom a flange.
cheers
https://www.sau.com.au/forums/topic/174844-tein-bonet-damper/
Details:
the item is full bolt on
space between flange with two holes: Centre to centre approx 6cm
green damper: fully extended about 29cm
Aluminium extension: 4cm
The head to attatch to flage: top 2.5cm
bottom 2cm
guys, want to let you know my mech has cut the tip of red bottle, is a lubricant of some sort.. so you'll prolly need some 4WD action to replace lost fluid..you also need a torque wrench to install..
