K&N rob
Be carefull with the high beam bulbs rob.
I know in the R32's they have a some sort of problem where it overheats the stalk switch and some times the light switch on the dash. Causing you to have no lights.
It has happened to mine and it also cooked the silver reflective plastic in the light its self.
Hence that is why one of my lights looks a little buggered.
Apparently it is due to on the R32's at least to much power being drawn through the light switch and stalk, some sort of relay setup needed to be installed?!?!
I was quoted around $200 to fix it, so i slapped normal bulbs in.. :D
R33's maybe different.
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-33134
Drifty,how many watts r they?
I`m doing a mod with adding 2 relays so both sets of lights are on when you flik to high beam(bright light,bright light).Then i`m fitting a rear spotlight so when Andy gets behind me i can switch it on so he will slow down and i dont have to put up with those bl**dy bright lights through the hills:lol: :lol:
Is your battery a GS Nippon(original battery) if so you might need an upgrade.
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-33139
Joel:
Yikes $200
They seem to work ok , car also already had the low beam ultra whites in it when I got the car and seem to be ok so far.... fingers crossed.
Andy:
Yep a bluebird, was pretty crazy, it took off , instant sideways, prob is I lauched and just sat there wheelspinning (damn stuffup launch, so i didnt even move, then it popped out of first gear... so went ahh well stuff it... they were little **** heads too, throwing abuse around , in was so tempted to get out of the car and beat the **** out of the loud mouthed passenger.. will prob do it if i see him again actually.
Bugalugs:
The bulbs ae 12V 55W, yep got origional piece of rubbish GS Nippon battery, Tonkins said I should upgrade it too. think i will have to.
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-33175
Guest veesixtyfour
Hey dude an chance of u documenting your install? :D
Sounds like a reallygood idea.. wouldnt mind pinching it if u dont mind of course :D
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-33205
Veeman,
Yeh no probs.I was going to do it today until i started stuffing around with my suspension then washing the car inside and out.
May do it during the week if the weather is good(no carport).
Drifty,
For Australia the K&N would probably be better.Cleaning a filter would be better than having to replace the element.
The watts are the same as standard so they should be alright.
Matt
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-33332
You can clean it more often that means more air getting through not clogging up like the one you cant clean.
I`m not sure with the K&N but with my Uni-Filter and Finer-Filter(for my buggy) i use Mineral turps to clean it then i let it dry then put the filter oil on.
I think the K&N would trap more finer dust particles than the Apexi.
Hey i saw that sexy looking commodore(JAFFA) cruising down Henley Beach Rd. tonight while i was going home from work.
Matt
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-34299
Rob,
If you are after a pod air filter than doesn't have to be re-oiled, have you thought about the Trust Airnx Air filter.
It is washable with water and soap.
You can get it both in a pod and pannel.
I think the pod costs around $200 and the pannel cost around the $100 (not sure on the last one).
Autobarn in Adelaide have them.
http://www.yellowpages.com.au/yp/search/bu...requestid=90394
Here is a bit of a write up on them.
http://www.takakaira.com/performance/trust...p3?index=airinx
https://www.sau.com.au/forums/topic/1749-kn-rob/#findComment-34315
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
